Spent some time talking with the guys at Chris Alston’s Chassisworks, and resolved a few open questions related to engine placement.
They agreed with the 1/2” offset, and encouraged anything up to 1”. I’m sticking at 1/2” because the passenger side header clearance between the torque box and starter is already fairly tight.
Also, I’ve been mocking up the elevation of the powertrain in chassis, and came to the conclusion that the transmission needs to largely be flat with the bottom of the rocker beams. A flat bottom should helps air flow and eases my design for shear plates. Mike at CACW corrected my thinking - I’m not raising the powertrain in the car, but rather lowering the car on the the powertrain, correcting my perception of the change to the center of gravity. I have about another 1-7/8” to adjust. This also ensures that in the case of a wheel failure, the first thing to contact the ground is a chassisember, rather than an oil pan or the trans.
With this update, I spent the evening making small adjustments, and mapped out the inner chassis structure - measure, draw on grid paper, transfer to bendtech. The trans mount sits roughly halfway, there’s room for two 3” exhaust tubes, and the driveshaft will poke down a bit toward the end.
Onward to the engine mounts and crossmember. The bushing plates I ordered arrive Friday, and I’ve started sketching that design.
David
