Drop Top GTX
A properly operating/prepared Thermoquad is very tough to beat.
Interested, do you have a link to the thread?For those interested, I have detailed some mods for the TQ secondaries over on A bodies. Really wakes up the TQ.
Jonas,
Sorry do not how to do direct link. But if you go abodies, Fuel & Air systems, you will see it.
forabodiesonly.com
This is not exactly the case since the large TQ flows easily 800+ cfm. The trick is the small primary and large secondary. The primary is about equal to the 750 primary side of a HolleyHow about a Holley 4175 650 CFM spread bore, vacuum secondary carb.....should fit the manifold....you'll need to adapt the fuel line and linkage......every one wants to over carb with an 800CFM Edelbrock AVS2 with a stack of adapter plates..?..bigger is not necessarily better.....
BOB RENTON
Good mentionJonas,
forabodiesonly.com
A classic example of over carburating a small displacement engine giving up crisp throttle response for the potential of peak RPM/HP. But where is the engine/car going to operate 90% of the time?...not at WOT but at mid rpm. Another consideration is what cam us used, rear gear, trans, compression ratio. Too many variables to say an 800 CFM carb is the best solution.....but to each his own volition.....This is not exactly the case since the large TQ flows easily 800+ cfm. The trick is the small primary and large secondary. The primary is about equal to the 750 primary side of a Holley
Various publications have stated that the primary is at 250 cfm on the large TQ. While I wouldn’t normally suggest a approx flow of a 400 cfm primary, it’s easily tunable for his engine. I using an 800 AVS II right now on a 340. Runs and drives excellent with very good mileage and driving manors. It’s all in the tune.
It really doesn’t matter if the little 340 only consumes 600 cfm on the dyno, simple fact of the matter, the 800 provides more performance and works very well.
