glrestomod
Thank you! It does misfire at the exhaust, one can hear and feel it. I just put new plugs in it because we added a brand new carburetor. The plug wires, coil, carburetor, plugs, alternator, fuel lines, fuel filter, voltage regulator on the firewall, ballast resistor as well as a cap and rotor button (has electronic ignition conversion and no points). I am new to timing, I may have the timing all wrong too.Yes when the engine is cold adjust choke and fast idle.
Idle adjustment when hot. Just a 1/4 turn at a time. Typical start point is 1-1/2 to 2 turns out from all the way in. But if you are already running just start turning the idle in until it starts to stumble and then come back out while watching the vacuum gauge to verify best adjustments.
Your choke in the summer is about bit under or 1/4” gap. That differs with engine though. You must be close.
Adjust your carb, take it for a ride , shut it down and take some plugs out to see how your adjustments are doing. If you have a good running engine the plugs should be tan colored. Your exhaust you reflect your plugs being tan colored. Not black and caked with carbon. Put your hand up to the exhaust and feel for a smooth pulse or popping misfire.
If you can read plugs you can do a lot of diagnosis. There’s lot of materials out there about how to read plugs. They tell you quite a bit of what’s going on inside your engine.
