troublemaker
So I got some clarification on the offset timing marks from Herbs Parts here in Delaware. He had 2 440s side by side that I could look at in various forms of teardown. You were right when you told me to rotate the crank 1 full turn to align the marks. I did try that and it worked well. I also learned that Mother Mopar also took into consideration fools like me would be messing around so they put an embossed pointer on the top of the block so you can align the cam sprocket, Who knew?, Certainly not me. Of course you have to rewire your distributor 180, the point is either way will work. Thanks for your help guys , I appreciate all your knowledge.
