Jonnyuma
- 7:24 PM
- Nov 15, 2010
I started muckin' around with my timing the other day in an attempt to find/fix an extremely high idle condition that couldnt be traced to the carb. When i manually turned the engine to TDC, the damper's timing mark was at 0 but the rotor was pointing at about 6 o'clock when it should have been at 5 o'clock (sm block 360). I pulled the distributor figuring the gear had somehow gotten 1 tooth off. With a telescoping magnet-y thing i got the slot pointed at the #1 tower (about the 5 o'clock position) but now the thing wont start at all. It got dark and i had to put my toys away so i never got around to checking for spark and all the other no-start troubleshooting, but im wondering if maybe i screwed it up worse than it was. If it was running with the dist so far advanced, but wont even start with it in the correct position should i be looking at the cam phasing and/or valve timing? The engine was rebuilt at some point by i-dont-know-who before i got ahold of it. Could the weird dist position have been used to compensate for something internal? Im gonna feel like a dolt if i find something crazy-simple when i get back to it, but to the best of my knowlege everything is hooked up correctly, i triple checked all my connections. Anybody been down this road. And if you have, did u have to push the car back? HA!
