Sweet5ltr
OK,,
Sorry for the late reply,,,, I checked the timing out today on my engine that has the same camshaft (MP .590" lift).
The base timing is around 18deg adv, and the total timing is around 36-38deg adv.
I use a non vac adv unit made by Mallory, so it's pretty easy for me to adjust base and total timing with a few twists of a screw driver and a good timing light...
I also have 1.6:1 ratio rockers too.... giving .630" lift (before lash).
I'm running the Crane Ductile Iron 1.5 Rockers. What did you set your lash at? Car seems to run better with 20+* initial timing. Going to purchase an SFI Damper before we go any further with timing, and go from their. I am using the Mopar electronic distributor with no vac. advance.
