lewtot184
The tire should have a stated maximum cold tire pressure on it. I use this as my guideline.
my cooper max pressure is 44 psiThe tire should have a stated maximum cold tire pressure on it. I use this as my guideline.
My father in law listened to the same B.S. that a mechanic told him to over inflate his tires on his SUV, to at least 36 -38 psi for a smoother ride. I was following him in my SUV and at ~ 65 MPH on a dry sunny Interstate highway, the left rear on his SUV, tire EXPLODED (the SUV was new with less than 7000 miles on the odometer) ..... tearing up the fender, fender well, body molding, chrome styled wheel......to the point of almost loosing control of his SUV, b4 coming to a stop on the side of the road. Did approximately $5k BODY damage to the SUV.......MORAL OF THE STORY......DON'T LISTEN TO THE B.S. proclaimed by others, including your best "buddy".....for they know nothing....and inflate your tires to the placard on the door jamb of the owner's manual or FSM.....BUT NOT TO EXCEED THE STATED PRESSURE ON THE TIRE'S SIDEWALL.....or do so at your own risk and suffer the consequences.......
BOB RENTON
First is follow placard on the door jamb.Personally......I'd be looking for a new tire vendor. I use what the tire manufacturer recommends not the supplier or installer .....
BOB RENTON
Steering will be much easier with some air in the tires. Tires will run cooler too.going start out 32 from the 26-27 lbs i had. want to see how the ride is and if the steering is a little less harder to turn at very slow speeds not worried about high speed wandering until i have the toe in checked and see where camber and castor specs are at.
I can always tell when my tire pressure is getting low because my gas mileage starts going to hell. Always wind up finding one or two tires down around 26 psi instead of the 32 that I usually run.That's kind of a mixed bag of questions and goals. The best tire pressure for handling depends on spring rates, what kind of driving and handling, etc. ... lots of factors. In general, I start at 32 in the summer and up it to 34 in the winter. I check tire wear and adjust up or down over the lifespan of the tire depending on how the tires wears.
For easier steering, up the tire pressure in the fronts to 38+. Check the tire sidewall for max pressure and stay 3-4 psi under that to allow for heat pressure build. A side effect is that your tires will wear more in the center and you won't get as much life out of them.
The 275x16s on my gf's Dakota can run 51 cold (runs low 40s)From Pirelli tire:
Running your tires at the correct pressure is important because it keeps you safe, cuts down your gas bill, and makes your tires last longer. Each vehicle has its own specifications for tire pressure, but most fall between 28 and 36 PSI (pounds per square inch).
