The 400 came out in 1972.As for a '78 400 or a '70 400. The specs will be the same for the engines
Just an FYI.
Yes, motor-wise, it will still be the same.That post wasn't directed towards you. I appreciate your help! Would the 70s chrysler manual cover the torque specs on a 400 from a 78 cordoba? I didn't see a specific one for the 78.
The pistons will need to be spec'd to KB info, not OEM. The materials and pistons are different, and react to heat differently.Its just a 78 400 bored 40 over with kiethblack 240 pistons, crank turned .020 on mains and rods, and a stock roadrunner cam not looking for a race motor just a cruiser for pokeruns
I would never tell someone to NOT get a service manual, but some of the information isn't necessarily the final word anymore, especially when it comes to torque specs...the part manufacturer's recommendations out-rank the manual. Things like aftermarket parts, better (ARP) fasteners, etc may have different specs than factory.
Same goes for bearing clearances...it's common to run them looser than the book calls for depending on the builder and the intended use, with no problems.
