ckessel
Might want to check the exhaust back pressure. You may be constipated. Can't go fast if you can't poo. Maybe a baffle or some other piece came loose in a muffler.
Others ive talk to have said maybe trans is slipping, but im sure i would feel like its slipping. Especially when at higher rpms
Running with open headers lol. Think that’s about as open as u can getMight want to check the exhaust back pressure. You may be constipated. Can't go fast if you can't poo. Maybe a baffle or some other piece came loose in a muffler.
I am using a gps speedo, this app has alway been fairly accurate for me usually with +/- 5mph maxIs the speedometer gear, in the transmission, rated for a smaller tire. It seems you already have bigger tires than you though. If gear is for smaller tires, bigger tires will give you slower read on speedometer.
Maybe, but I really don't think thats the issueThen again, you dont crap straight out from yer stomach lol
Yes there is an rpm drop, but not a whole lot. Maybe around 500ishrpms while at full throttleMaybe what you feel 3rd gear kicking is it trying to but not? Is there an rpm drop?
Torque converter is brand new, also did the same with another 3k stall unit.Torque convertor
Well true but what are the chances i got 2 bad converters from reputable companiesJust cuz it's new doesnt mean...
Last week when I changed converter i also changed the fluid. Looked ok and had some glitter in the trans fluid. But i would think if it was slipping i would feel it? Maybe im wrong?sounds like somethings slipping, fluid smell burnt?
Im at a loss as well...IDK my man, Im at a loss. Ill just make some popcorn for everybody and see what you can come up with
