inri
Hello all,
I am installing a 10" torque converter into a 727 small block. I believe I have fully seated the converter because it sits inside the bellhousing 1.25" (measured this). My first question is, if I pull on the converter it will slide out all the way, is this suppose to happen? For some reason I'm thinking it should not...
My 2nd questions is regarding connecting the transmission to the engine. I have been trying to get the converter knub to slide into the crank (used grease on both) but I'm having a really hard time to get them to line up 100%.
Would it be better to line up the engine dowel pins and then align the bellhousing flush to the engine via the dowel pins and then install the bellhousing bolts? By doing this, the converter knub would then be basically pressed into the crank.
Thanks for your answers!
