- 10:52 PM
- Apr 13, 2012
- Granite Bay CA
I mentioned before the tendency when working on a big project to keep finding more and more things to do....I call it The Snowball Effect.
Succumbing to that often turns a 3 week project into 3 years.
It is tempting to address every little thing you see when the car is apart. It makes sense to fix things that are now right in front of you but at the same time, you have to know that each diversion delays the finish.
Some things you can't ignore, stuff that gets buried makes sense to fix even if it delays the completion.
At first, I figured to leave the exhaust connected to hold the engine in position. Once I removed the right header, I started to think about how the engine has sat out of level for awhile. The passenger side sat lower by a noticeable amount. I figured that with a new transmission going in, I should get the engine sitting right.
