Sometime in 2013 or so, I made some wiring changes. I moved the battery to the trunk and ran new wires and battery cables through the inside. In 2015 I changed the instrument cluster. This setup is a Dakota Digital. They use a master "brain box" that receives all inputs then feeds the info to the instrument cluster. The speedometer uses a speed sensor, not a cable. The water temp and oil pressure sending units are different from stock.
Seeing as how back then I had ZERO intention of converting this car to a manual transmission, I used the hole in the firewall (Block off plug for the clutch linkage) to pass the many wires through. Now I had to make room for the clutch pushrod.
I looked at the firewall to find another way to run the wires. I had the water temp, oil pressure, Ign 1 and Ign 2 wires, a tachometer wire and the one that goes to the rear view mirror. The mirror has a compass and thermometer and is auto-dimming.
The black 1/0 cable running horizontally, then going through the firewall below the oval plug is the main battery cable. It is electrically DEAD except when cranking the engine.
Above the oval plug and to the left is the original speedometer grommet, now on the power wire for the electronic speed sensor.
Note how many wires go through the oval body plug. I was curious about how I would reroute them. Would they then be too short and need soldering to extend them?
Also, which end of the wires should I disconnect? The water temp and oil pressure wires were wrapped into the harness, the temp sending unit is under the A/C compressor too.(Tough to reach) I decided to remove the instrument panel and pull the wires from the cluster. It was almost a 50/50 deal as to which way would take the most time but I'm glad that I went this way about it.
I found a hole in the firewall below the bulkhead plug. It formerly served as a mounting hole for the old heater-A/C box. Directly to the left of the hole is the starter relay, you can see the screws poking through. This was the new pass-through that I decided to use. The IGN 1&2 wires need to attach to the relay anyway and this will make the underhood wiring look cleaner.
I looked through the body plugs I had and picked a 1" plastic one
I looked through the body plugs I had and picked a 1" plastic one....
I took the die grinder to the hole...
I hogged it out enough to fit the plug..
Then ran the wires through a hole in the plug.
Oddly, all of the wires were actually LONGER now since this was a simpler routing than the other way. Underhood looks cleaner.
You can see some light shining through the opening in the round plug.
I'll dab a bit of sealant on the cluster of wires to seal it up nice. This was a task that I didn't think would be this easy. Lucky ME !
