Ok fellas, I'm going nuts. I am trying to not repeat the same mistake twice.
Previously, I F'ed up 383 assembly. I had my timing marks at 12 and 12. Pulled motor, opened her up after running like crap.
Ok - now trying to get the ignition timing correct.
Currently, Heads are off, #1 piston at TDC, cam installed, crank and cam sprockets installed, chain off.
I understand that when the timing mark in the crank sprocket is at 12 O'clock
And the mark on the cam sprocket is dead on at 6 O'clock - the timing is set.
But wait, that could be 180* off!
I greased and dropped in a couple lifters for #1 cylinder.
After spark, the next valve to open should be exhaust, right?
After the cam timing mark passes the stationary straight up crank timing mark, the next opening valve seems to be Intake.
BB 906 Head configuration E-I-I-E-E-I-I-E no matter which way.
My first lifter (exhaust) should be first to open after spark which should occur when marks are cam 6 crank 12.
PLEASE HELP!
PLEASE HELP!
