74Runneer
ok...lets put our bets on the table...:blob1:
I'm betting something to do with the timing...maybe slipped a couple of teeth on the chain...
2nd cause...something awry with the head work, or head/s installation....
No, just no. Its going to be a wire. 1 single wire that was disconnected. Nothing else.
The fuel tank and temperature gauge are both fed from the Voltage regulator - so I would check that the VR works first, fuel tank only usually means a ground wire missing.
As for the speedometer - there is a handy table below to work out the pinion tooth number required to make your speedometer work 'close' to correct. Table borrowed from another site. Measure your tire height and look up the pinion required, according to diff ratio.
http://home.earthlink.net/~mopared/speedo.htm
Okay how do i check to see if my VR works properly?
Also im not sure of my gears but i can just jack up one tire, rotate it twice and count the revolutions right?
Hey, thats 20!
![success[1].jpg success[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/101/101740-2b1900e61b766f52bb39409830b795c3.jpg?hash=KxkA5ht2b1)
