superfragl
That sound decent for an engine with non-stock cam.
I gotta be careful! Might learn something. Never have tried setting mixture, using vacuum...might look into it, for grins.Turning the mixture screws 1/4 either way has no effect on vacuum so I'm not sure how to get it right. More reading ahead!
It's pretty common on carbs, not to get a mixture response, in a 1/4 turn. Not if it's in range already. Also takes a few moments, for the mixture setting to 'catch up' with the motor. That's why they say do it slowly. But, I'll toss in, mixture cannot be adjusted, if the idle speed is high enough, that the carb is out of the 'idle circuit'. Position of the throttle plates control that, on any carb. Guessing anything over 750-800 RPMs, is too high.
12 volt batteries full charge is 14+ volts. Sounds like your getting there. Wiring getting hot...not so good. (Might peek at your fuse block, too.)
Think you've got your VR acting right, now?
Another story, but my alternator is 80 amp, though I also added in parallel wiring, to help with the normal loads.
Hmmm...yes, my timing light, is a simple one (kinda old, too), but works great. Strobing too fast? Should only hit off #1 plug wire. Don't think your getting cross-fire, do you? No, don't see that, unless something is happening under the cap.My timing light is a simple strobe but is strobing too fast now for some reason.
Took the distributor apart. The gap was tighter than .006. Easier to do in a vice.
View attachment 523966 View attachment 523967 View attachment 523969
Getting the vac advance disconnected is fun!
looks like 26* mech.
