eagleone1983
I have a couple unidentified wires. The harness is an M&H Electronic ignition harness for a '69 RR. I have a Denso alternator that takes the circular plug with three wires hanging from it. I have a write up from Andy F that explains what the three wires are for in the new plug. He also states he just extended the dark blue wire from the Voltage Regulator and run an extra wire for the sense wire.
So what do I do with the wires in the pictures. The single dark blue wire has continuity with the dark blue wire at the VR plug, so couldn't I just use that wire for the IGN wire to the alternator? In the other pic I know it's kind of shadowed but there are two wires going into a single lug terminal they are a thicker black wire and a violet/purple wire. Thanks for any help.
