Polsky
Hi crew,
Last week I started a thread on a possible 440 budget build, since my car is going through over a 1/2 quart of oil every 500 miles. As promised, I did a compression test. Here are the results:
CYL:
1-151
3-149
5-142
7-151
2-150
4-145
6-152
8-136, wet 145
I added some oil to the lowest pressure cylinder and tried the test again. The garage was at about 50 degrees but the car really smoked for the first 2 minutes of start up. The car is running a little rich if that matters. Oil pressure was at 75psi cold @1300 rpms and 50 psi at 165 degrees and 1000 rpms. The cylinders are just in the 10% rule of thumb for the test; but does this look ok? I am almost looking more toward a valve seal/guide problem. I look forward to any suggestions. I do not have allot of info on the motor internals beside it has a 484 MP cam, 906 heads that look clean, and what I am assuming is stock 1968 bottom end with a windage tray. Last, if it looks like a head issue, would I be able to run a set of stealth or e street heads with the stock valve train and still make it on 91 octane? Thanks in advance for any advice.
CYL:
1-151
3-149
5-142
7-151
2-150
4-145
6-152
8-136, wet 145
