- 12:57 PM
- Jul 1, 2015
Bill Monk,
Your premise is partially correct. Most or all of the new cars are computer controlled and measure manifold vacuum as MAP or manifold absolute pressure. This is an inverse function of vacuum...high MAP (760 mm mercury) equals low vacuum. In addition, RPM, inlet air temperature, throttle position, engine temperature, transmission gear selection, fuel density (flex fuel cars), and most importantly, AIR FLOW into the engine, measured in grams per second, which includes the air density factor, are all inputs to the computer which calculates both the degrees of spark advance AND the fuel flow on time to the injectors as a function of the pulse width modulated on time (open). The result of the combustion event, the oxygen sensors keep the fuel calculation at the ideal 14:1 ratio. The newest technology is gasoline direct injection where the fuel is directly injected into the combustion chamber, slightly ahead of the spark occurance . There are knock sensors listening for pinging that retards the spark slightly. Is this better than just the distributor advance system of old....YES absolutely.
Resulting in lower emissions, better performance, better fuel economy, and drivability.
Bob Renton
Bob Renton
