Vacuum Leak Possible-Questions
bad88ttop
4:34 PM
Pittsburgh, PA
Hi guys,
I have a 440-4 that I've recently re-gasketed, repainted and detailed for one of my 70 Chargers. While the engine is at idle (4 speed) it has a shake/wobble to it. No hesitations off idle or acceleration problems but it does bounce around a bit at idle. I keep the idle down around 850/900 rpm and it does house a lumpity lump lump camshaft at idle/duration. I've sprayed the intake down with starting fluid, no change. Just looking for ideas to try over the holidays here. Thanks
look down the carb as it runs to see if fuel in dripping / bleeding over. or remove spark plugs and inspect if you dont understand how to read a spark plug then take rely good pic's looking down in side plug and post i will bet someone could tell how good the carb is. also could be carbon track in dizzy cap.
