I have Edelbrock Performer RPM aluminium cylinder heads and a Performer RPM cam shaft on the original 383 in my 69 Charger.
All this is installed by previous owner, but I'm changing the cam because it is wiped out. During assembly I found that at least one of the pushrods are bent (yes I should have checked them when I took them out).
In earlier conversations with my parts supplier I was told the stock non adjustable rocker arm assembly and stock pushrods could be used with the heads and cam in question. Which the previous owner of the car has done.
Now I will order heat-treated chromoly.
Can I use the stock rocker arm assembly or do I have to get an adjustable one?
If the stock actually can be used, does anyone know if the pusrods should have stock length?
Guess I can find some answers online and that I might have to measure for push rod length....
Thanks!
Thanks!
