- 6:22 PM
- Apr 13, 2012
- Granite Bay CA
Summer time is coming and you know what that means for most of us. Car shows, road trips. cruising and other fun stuff in warmer weather where vinyl seats mean sweaty shirts and bad hair.
The hair part won't matter to some of you but the overall theme still rings true....cruising in an older car is great but does carry with it some concessions.
It doesn't have to be that way. Many of you have made it a point to make your classic as comfortable as you can.
This Plymouth is probably like your car. It is a well put together car that stops and steers well. It makes a bunch of power and has a good street vibe going for it. The owner has made some great choices in terms of drivetrain and overall engineering which should come as no surprise since he is a trained engineer by trade as well as being a fellow FBBO member.
Follow along as I install a Vintage Air HVAC system in this Plymouth. I have some obstacles to deal with that I still haven't figured out yet but as with most build threads on these forums, I often see many helpful suggestions come up from fellow members that end up being a huge help for the installer.
This car has a 400 block based 451, a classic Mopar hot rodders stroker build using a 440 crank in a 400 block. This means it is a low deck, much like a 383. This affects little except the mounting for the alternator brackets. The car came to me with the standard two belt arrangement as is common for non A/C cars with power steering. The owner had aftermarket pullies for the water pump and crankshaft but he didn't trust them. I've read of and seen a few that cracked and fell apart...a situation that often results in a whole lot more damage when you shred a radiator, shroud, fan and maybe even send flying parts through the underside of the hood. First up was to pull the stock pullies and install refinished original A/C parts from my stash.
(The advantage of hoarding parts you almost tossed out)
