The no no lead adapter are for those people who liked blood poisoning and brain damage.Here are a couple of interesting items. At first glance, the timing light looks ordinary. But if you’ll notice, instead of using power from the engines electrical system, this light gets plugged into a wall socket. I haven’t tried it yet, so I am just guessing as to how it functions. I think the probe is Either brought into contact with the spark plug wire, or is inserted into either the spark plug boot, or the distributor cap boot. It seems to be a precursor to today’s inductive lights. Unfortunately, I don’t see a manufacturer’s name anywhere on it. The second item seems to be a device that would have allowed you to pump leaded gas into a car that was built To only except unleaded fuel. If you recall the unleaded cars had a small fuel tank filler neck opening. Since the nozzles of the leaded gas pumps were larger, you could not fit one in an unleaded cars filler neck. I have no idea why someone would want to burn leaded fuel in an engine designed to burn unleaded fuel.
Here they just enlarged the opening, used regular fuel, adjusted timing and carried on. When the catalytic converter acted up, it got chucked.moparedth, I agree.The early to mid 70's cars ran awful. Unleaded was coming in around 1972 in our area.Chrysler was almost belly up around 1974 and did anything to get these cars to pass federal smog requirements. Timing was 2* after top dead center on the 318's. We sold lots of Aspens and pickup trucks.Constant customers coming back . We would remove all the vacuum junk and miles of plumbing,hook the vacuum advance up like the 60's 318's and bump the timing up to 8* advanced. Most were happy campers after that. Our state (PA) had no smog inspections at that time.
Sorry guys, got a little off track.
In the early days of unleaded gasoline, leaded regular was a few cents cheaper than unleaded, thats why people would put leaded gas in their unleaded cars. Gas powered cars and trucks still have the small hole filler necks, diesels have a larger hole like the leaded fuel vehicles had. You can buy both sizes of nozzles.Here are a couple of interesting items. At first glance, the timing light looks ordinary. But if you’ll notice, instead of using power from the engines electrical system, this light gets plugged into a wall socket. I haven’t tried it yet, so I am just guessing as to how it functions. I think the probe is Either brought into contact with the spark plug wire, or is inserted into either the spark plug boot, or the distributor cap boot. It seems to be a precursor to today’s inductive lights. Unfortunately, I don’t see a manufacturer’s name anywhere on it. The second item seems to be a device that would have allowed you to pump leaded gas into a car that was built To only except unleaded fuel. If you recall the unleaded cars had a small fuel tank filler neck opening. Since the nozzles of the leaded gas pumps were larger, you could not fit one in an unleaded cars filler neck. I have no idea why someone would want to burn leaded fuel in an engine designed to burn unleaded fuel.
Arco Graphite, "The Black Oil" as they used to advertise it.After posting those first pics, it got me motivated to get the pile of cans taking up floor space and get them on the shelf. Here's pics of that project, until I ran out of room (which seems to be a recurring problem in my garage). I think I am going to make some oil stands out of wood that would look the ones that used to sit in between the gas pumps back when pocket change could get you enough gas to go cruising.View attachment 744395 View attachment 744396 View attachment 744398 View attachment 744401 View attachment 744402
Correct ! Regular leaded was 27 cents and the unleaded was 32 cents !!leaded regular was a few cents cheaper than unleaded,
For the first couple of years after I got my drivers license regular gasoline was 26 cents. $2 would let you cruise around all night.Correct ! Regular leaded was 27 cents and the unleaded was 32 cents !!
Customers would complain ! Now you know how old I am...
Early 70's?I started working at a Boron gas station at 13. Boron was the only station that had 3 pumps.
Regular,Premium,Unleaded..When I said the customers complained is when prices would increase 2 cents.
At 13 regular was 19 cents. Don't forget those S&H Green Stamps..
