Leak from the bellhousing
The good news is this time around should be way faster!
Unfortunately, it was a timid test drive. It's pouring out so I decided that I would learn from my mistake of almost thirty years ago when I wrecked my Hemi Roadrunner in the same conditions. Not this time!!!!!!!!!Howd the test drive go? Where'd the converter put your rpm?
have fun & good luck, curious to hear how the new set-up works with all the rest of the stuff...
Did you do the single 4bbl intake & {good Holley/Quckfuel} carb swap yet ?? or just gathering info still
What was the weather diff between the best and current runs?
Regardless of ET, where the f did 7 mph go?!?!
Very likely might not like to RPM. Have a chassis dyno near you?
that old 1.91 - now 1.76 60ft is good for about .3 tenths on the big end, should be at-least 11.90's are you getting enough weight transfer, to get traction/hook with the drag radials...
I needed about 5''s of front end lift to get the old M/T 315 drag radials to hook "at all" @ 16psi IIRC, with the rear shocks {Lambs double adjustable, front & rear} set pretty damn soft, only like 3 clicks compression, so the car would lift the front & squat in the rear, with-out hitting the tires way too hard {I had a completely different combo thou, 479ci, 3520#'s w/3.73:1 ran the best mph, but gave up a little 60' times, about a tenth & a 1/2 over the 3.91:1 - 4.10:1's very little change between them 2, my 3800 converter that flashed to 4200 rpm when I nailed it, worked way better with the 3.73:1's than any other gears, I also had CalTracs}...
just spit-balling, throwing stuff out there...
you'll get it, it takes some fiddling/tweeking some times...
IMHFO use a test & tune day is the best way, make lots of 330" runs first, get the car to work & hook, then worry about getting the rest of the way down track...
take lots of notes, keep a detail log...
keep track of everything, shocks, tires, tuning, launch RPM, temps, including track & weather conditions too, it all can have a drastic change in performance from day to day...
Thats what I was going to ask ? Where did all the mph go. I mean 113 can get you in the 11's with a good 60 ft but it wont get in the 11's with 106 mph. Do you know what hurt the mph so much ? Ron
Hey bob, there's a chassis dyno on the road down near raceway park. Not sue if it's old bridge or englishtown.
It's like a 2 bay repair shop on the right hand side couple miles before the turnoff for the track.
I'll have to look around. There has to be one a little closer than that. If not, I can wait for Carlisle. Thanks for the heads up.
