70chall440
- 4:16 AM
- Feb 11, 2018
- Yelm, Washington
Its kind of funny to read things like this and all the people who come out in support of the old technology. Sure it worked (to a point) but obviously there was a reason the manufacturers went away from it; was it cheaper, not even close in this case, so why then did electronic ignition become the standard for every car manufacturer? Well before the "emissions" hats comes out, I would argue that while this was a part of the reason, it definitely was not the entire reason. Electronic ignition became the standard because it was in fact more reliable, produced a more consistent spark and was more reliable (little to wear out, little to "slip", etc.). Sure, they had problems just like everything else but overall they were/are better. This is the same issue with EFI and despite what some will say it is better is almost every way other than perhaps WOT runs.
Hey, if you want points then so be it, your car and you can do what you want. For me, I will put electronic ignition and EFI on everything I can as soon as I can. Hell, I even put electronic ignition on my 48 Ford 8N tractor. Used to be I would have to pull of the distributor cap and clean/gap the points at least once a year but since I changed over I have never touched the distributor (over 5 years ago).
