Hey guys as I get closer to getting down to bare metal inside and out (about 90% there) I am going to need to clean all the metal off. What is your process of cleaning prior to epoxy prime coat of bare metal?
Thanks for the tip Stanton. She’s awfully dirty from all the sanding. Was wondering if there is a more robust way to get it all clean prior to hand cleaning. Like using a liquid mix spray of something. Would love to hose it all down and then treat with phosphorus acid. Does anyone do that or is that a big no no….Use wax and grease remover in a spray bottle. wipe till the rags no longer pick up any dirt. You can "metal prep" afterwards - metal prep needs to be applied to bare metal that's free of any oil or grease. Save your lacquer thinner to clean your paint guns !!
