Jonnyuma
- 4:16 PM
- Nov 15, 2010
I installed new FelPro intake (and valve cover) gaskets yesterday and followed thier admonishments to install them dry w just a little hi-tack adhesive on the cork end-rails and a 1/4" bead of rtv in the corners. This is the first time I've actually used the cork end pieces, and the first time I've had a massive failure....
After letting everything set up for 20 or so hours I went to start the car, warm it up, set the timing and adjust the carb so I can get to work tomorrow morning.
Instead I got coolant POURING out of the front intake/block mating surface and, as I suspected, into the lifter valley and subsequently the oil pan. Not good. My oil now looks like a chocolate milkshake.
Okay, so...now I blow it all apart again, diagnose the failure, find a ride(s) to work for the week, and, hopefully, fix it next weekend (all of this still needs to be done. I better get busy!). Now that water/coolant has been introduced to my oil, my main question is: How Do I Make it Go Away?! Multiple oil changes? Wipe out the Goo in the lifter valley? Hose down the cylinders with some WD40? This is my daily driver, not a hobby or race car. I'm sure a full teardown and rebuild would be optimal, but I can't pull that off right now.
