64plymouth
My experience with shift points. First torque flites have a pretty long time lag on the 1/2 shift. They don't slip. Just takes time to fill the band servo. The quicker the car, the earlier you need to shift to hit your target rpm. This time remains constant, regardless of ET. The quicker the car, the earlier you need to shift. On the 1/2 I'd start 400 RPM early. Might even take 600 rpm early. Unless you have a playback tack or film the tach you'lll never know when it right. Second crossrams on a big motor don't like a lot of RPM. That intake was designed for a 413" motor turning maybe 6000 tops. They can be effective. when used in the correct range. For sure there is stuff thats quicker.
Doug
I do have a playback tach and I did notice what you are saying about lag time. I'm a little east of Wausau (Shawano County). WIR is closest for me I have been going for their Friday night test/grudge. Still trying to get a hold of PTC and Ultimate. I punched in my numbers for convertor slippage and shows 15% slippage. Friday the 30th is WIR last night. I might be waiting till next spring. Or going down to Da Grove they run longer if weather permitsI am in Wisconsin too - where do you typically race, and isnt all of Wisco deer country
Historically these type of situations always seem to lead to a converter. Given that everything else is on point. But I suspect that intake, although bad ***, may be the first thing I would try and swap out.
