Curiousyellow71
LolWell thank goodness for that.
Gasoline is dry period. Avgas has "no" ethanol so there is no water absorption. Can't have water at high altitudes due to freezing. Being "dryer" has nothing to do with lubrication. The lubrication from Gasoline is the lead for the valves, that's it. Cylinder lubrication is from engine oil and oiling rings. Avgas is for reciprocating or opposing piston engines, whereas jet fuel is oily and used in turbine engines w similar characteristics to diesel.I heard AV GAS is drier so marvel might be a good thing . My older client (76) swears by marvel oil . he adds it to engine oil.
Pretty much none of my cars ran as good at factory specs vs tuning them 'up'. Always had better off the line response with more initial advance....also got better mileage with the timing set up that way. My /6 cars responded well probably due to the low compression of them.I understand that AV fuel is a dry fuel so that air planes don't have icing at altitude in the fuel system. I add the MMO for the fuel, not necessary for the car, but feel it does help with the fact that most of my old engines don't have hardened valve seats. I also use some lead additive for this reason. I'm probably old and set in my ways and it may be totally useless, but makes me feel better and hasn't caused any problems.
I can tune my old 440's and 383's back to factory spec's and they run like they did in the day. Having to detune an engine run on 90-91 or 93 is in my opinion more detrimental than giving it what it was designed for.
That combo should run fine........ with a 252 at.050 cam swap, a set of 3.91 gears, and a 3500 converter, LOL.There is some speculating as to what might work with different combinations. Here is what will not work:
440
915 head
222 degree @ 0.050 installed at 109
10.3:1 CR (Measured)
190-195 psi on the gauge
Good quench
93 octane
1000 ft elevation
160 degree thermostat
crossover blocked
NGK-7 plugs
No vacuum advance
Full timing in at 2500-2800.
The car is heavy, 3.23 gear, and stock converter. There was no reasonable ignition timing that would allow this motor to run well without detonation.
The detonation was significant.
I'm not sure what "dry fuel" means in regard to AV gas? I believe that for high altitude operation, the fuel may have more volitility components to allow for easier evaporation at colder ambient temps plus combined with carburetor air preheating (to prevent icing, due to gasoline's latent heat vaporization property and moisture in the air). The lead additive in AV gas is the exhaust valve seat "lubricant", which I would use if it were more readily available. I also wish I could be able to have a storage tank on the property to be able to fill up as needed. The propaganda for MMO states its not harmful to catalytic converters, so it cannot contain any lead compounds, but does do "marvelous" things: (from a MMO advertisement) Marvel Mystery Oil helps unleash maximum power and performance while extending engine life. The original oil enhancer AND fuel treatment cleans the engine from the inside out, increases fuel economy, and protects against temperature extremes. Regularly use Marvel in your oil and fuel for a smoother, quieter engine. (But it does not explain exactly how this is accomplished).I understand that AV fuel is a dry fuel so that air planes don't have icing at altitude in the fuel system. I add the MMO for the fuel, not necessary for the car, but feel it does help with the fact that most of my old engines don't have hardened valve seats. I also use some lead additive for this reason. I'm probably old and set in my ways and it may be totally useless, but makes me feel better and hasn't caused any problems.
what a doll!I don't have to hide anything from my wonderful wife...
View attachment 1175702 View attachment 1175703
I don't remember where I saw the the dry fuel come up in relation to av gad but will look into it, I had a client that used to work a t the refinery , I miss him now>lolI'm not sure what "dry fuel" means in regard to AV gas? I believe that for high altitude operation, the fuel may have more volitility components to allow for easier evaporation at colder ambient temps plus combined with carburetor air preheating (to prevent icing, due to gasoline's latent heat vaporization property and moisture in the air). The lead additive in AV gas is the exhaust valve seat "lubricant", which I would use if it were more readily available. I also wish I could be able to have a storage tank on the property to be able to fill up as needed. The propaganda for MMO states its not harmful to catalytic converters, so it cannot contain any lead compounds, but does do "marvelous" things: (from a MMO advertisement) Marvel Mystery Oil helps unleash maximum power and performance while extending engine life. The original oil enhancer AND fuel treatment cleans the engine from the inside out, increases fuel economy, and protects against temperature extremes. Regularly use Marvel in your oil and fuel for a smoother, quieter engine. (But it does not explain exactly how this is accomplished).
If your satisfied with the product....great....I'll just use the Sunoco 112 octane leaded gasoline with 93 octane pump gas.....
BOB RENTON
The heating (energy in terms of Btu/unit) value ethanol is roughly half that of gasoline, therefore you need to burn 2x that of gasoline, or the percentage of ethanol in the blend to achieve the equilivant energy. Manual tuning by adjusting the jetting of the carb is time consuming. This is the reason for mass air flow measurement with fuel injectors on time (pulse width modulated) with down stream O2 measurement, corrected by temperature, manifold absolute pressure, spark advance, RPM, throttle position and fuel density (which measures the fuel composition) which is why the newer engines work so well.Years ago I asked a relative in the aviation industry about 100L. He also said its a "dry fuel" but was never specific as to why...it never made sense to me either calling a liquid... dry. Propane and natural gas are what are associated as dry fuels.
I would think raising gas octane enogh to make a difference with e85 while running a carb would take a lot of fine tuning and be difficult since ethanol takes more volume to get the same btu. Fuel injection I would think would work better.
A little read about 100LL. It's certainly higher quality then what cars get. The octane rating is also different.
https://www.shell.com/business-cust...centre/technical-talk/techart12-30071515.html
Low rpm + high load= more knock sensitivity
Yes. But not nearly enough to run pump gas at 11 to 1 with a 225° at .050 cam.So a higher stall and or gearing , would help lessen the sesnsitivity?
In california, that would be a great price for 110 unleaded (I assume).
