69Coronetrt
[/QUOTE]How and who makes new fender tag and broadcast sheet? I need them.
QUOTE="HawkRod, post: 912094445, member: 7773"]My 70 Road Runner is missing the fender tag. But I also never found a BS. All the number match though: VIN, core support, trunk lip, engine & transmission. Having said that, there is no way I can reproduce the fender tag so I haven't and I won't. That would be fraudulent. I have to just "prove" what the car was/is based on pictures.
You are in a different situation. With your BS, you can reproduce the fender tag and back it up since you have documentation to prove what options your car had.
I say reproduce it. You are not scamming anyone, and you can prove what is on the fender tag if anyone ever had questions (like if you were selling it).
Just my $0.02
I'm not sure who's post this actually is....
There is this continuing erroneous belief that simply having a BS means you can get an accurate tag. It helps with some info on the tag but plenty of bad tags have been made with the BS present.
Having a BS does not tell you what was coded on a tag, when it was coded on the tag or even where it was coded on the tag. It does not tell you the gate, base and sequence numbers for Lynch Road cars. One still has to have plant, year and time of year knowledge.
Guessing at info or what should or should not be in a tag simply to have a tag is not reproducing a tag; it's guessing.
