Oil recommendations are like @ss holes, everyone has one and they all stink, including mine.
Ran the Lucas break in oil (dyno break in then dumped it) then ran it for the first 500 miles then switched to the Lucas High Zinc Hot Rod 10w-40 in my 500" stroker, BIG solid flat tappet cam.
Cut the filters open after each change and inspect. Any problems will be obvious.
It takes almost 20 mins for the oil to get to its full operating temperature, so need to factor how thin it will be warm, any 30 wt oil should be fine, I use Penrite 20w-60 with zinc in my fresh 440, with high volume pump with std spring and its about 70psi warm, 80 odd cold, according to the gauge.
