- 2:48 AM
- Apr 13, 2012
- Granite Bay CA
This is a serious question.
Bad news goes everywhere but good news often hides in the shadows. I know that there are many of you that have never had a cam go flat so let's hear from you!
Before I went all Mopar, I had a few Chevys. I never had a cam go bad with them despite Chevrolet having a recall in the late 70s for that very thing.
In all of the Mopars that I've owned, none of the stock engines had a cam/lifter issue either. It was only after I stepped it up a bit and went for increased performance.
In 2006, I used a Comp Cam 285HL in my 440/493. It ran great, sounded great but lost a lobe within about a hundred miles. I used the assembly lube, I used Valvoline oil and I did the break in but the engine ran hot within the first 15 minutes so I had to shut it down to cool off. When I went to restart it, I got no spark. I kept replacing stuff until it finally ran, at that point I finished the break in. Summit Racing warrantied the cam and sent another.
The second cam from Comp was the same grind. It lasted a few months before the same thing happened again. I took the 292/509 I originally had in the engine and slipped it back in with new lifters. It held up fine. I pulled it a few years later when I tried the Lunati solid in an effort to stop the detonation.
In 2022, I lost the MP 528 solid after having it in the car for 8 years. Sometime in 2021, I switched oil to a synthetic with a high detergent. I was told that the oil itself was probably to blame.
Back in 2010, I lost an MP 292/508 in the 360 I built for the FrankenDuster....
By all accounts, I did everything right with that one. I still never figured out why it went bad.
I have other cars here with flat tappet cams but they show no signs of failing. The 360 in a Dart, the 440 in the Power Wagon, the 360 in a 72 Duster all are holding up fine.
I am not a trained mechanic but when I am trying to determine the cause of a problem, I look for a common theme.
The only cam failures I've seen have been in rebuilt engines aimed for higher performance. Higher performance often means non stock parts, stiffer valve springs and higher compression.
There has been all sorts of discussion over what causes these failures. Some blame the manufacturers for making crappy products. There have been tests to show that the hardness of the metal in the camshafts and lifters is no different but there have also been some that found too little taper on the bottoms of the lifters. Some blame the valvesprings for being too stiff, others blame the oil. There are engine builders now that refuse to install flat tappet cams because they don't want to risk a costly warranty return.
You may just default to the argument to switch to a roller cam and that is a solid argument, but.....
Why do so many flat tappet engines survive? I know of several guys that have not dealt with a cam failure. What are they doing right?
Are you one of them that has never personally lost a camshaft?
