- 8:43 PM
- Oct 25, 2010
- Monroe, New York
My dad would occasionally bring home 8mm movies from the MD library. We'd gather the neighborhood kids and have a show in the basement. First one I remember was the Streak Eagle. Showed it chained to the runway so the pilot could go to max A/B without skidding down the runway. Released the chain, explosive bolts I think, and it took off like a bat out of hell. Climbed while pulling a 1/2 loop, rolled over, leveled off for a bit and then climbed again.at The Air Force Museum..
The museum's single-seat F15A, nicknamed "Streak Eagle," broke eight time-to-climb world records between Jan. 16 and Feb. 1, 1975. In setting the last of the eight records, it reached an altitude of 98,425 feet just 3 minutes, 27.8 seconds from brake release at takeoff and "coasted" to nearly 103,000 feet before descending. It was flown in its natural metal finish to reduce weight for the record-setting flights. To protect it from corrosion, McDonnell Douglas Corp. has since painted it in the gray color scheme of most operational F-15s.
keep the photos coming!
Ditto on the F-4, used to sit at Ammo dump watching them take off from DaNang air base. My oldest worked on de-icer setup for lift fan on F-35(after "they" figured out there may be cold temp operation) at UTC.My dad would occasionally bring home 8mm movies from the MD library. We'd gather the neighborhood kids and have a show in the basement. First one I remember was the Streak Eagle. Showed it chained to the runway so the pilot could go to max A/B without skidding down the runway. Released the chain, explosive bolts I think, and it took off like a bat out of hell. Climbed while pulling a 1/2 loop, rolled over, leveled off for a bit and then climbed again.
Other movies showing F-15's attacking ground targets were pretty cool too. Those came out when they were marketing the F-15 as a ground attack aircraft in addition to its air superiority role.
