Who Rebuilds A/C Compressors?
Road Grabber
2:35 PM
Sarasota Florida/NY State
I have a 1970 Dart Swinger 340 I’m putting back to original.
Classic Auto Air no longer restores AC systems. They only deal now with retrofit.
Is there another vendor out there that will rebuild compressors to original specifications?
Does anyone sell rebuilt compressors?
Has anyone rebuilt a compressor and know of parts available to rebuild compressor?
The gaskets are getting hard if not impossible to find lately. It would be nice for someone to do a run of a few hundred kits, but it's costly - stamped metal, composite, rubber, etc. The shaft seals are available. I would replace the shaft seal, maybe the front bearing. Make your own bottom oil sump gasket and clean the interior of the "pan" real good. Reassemble with new oil, Ester if converting, mineral if spending the $$ for R12.
Thank you for the replies. I have no problem with rebuilding or putting in replacement seals. I’ll have to spend time getting the part numbers.
From the parts manual:
AC Part packages from section PK
Compressor exploded view from Section 24 "AC" - you'd have to look up each individual item-type's part number(s) in the sections parts listing. It's multiple pages, so I didn't extract.
After poking around on the web today for a rebuild gasket kit it looks like somewhat slim pickings. Classic Ind. used to have a gasket set and a shaft seal set but no longer available. Looking in the parts manual and what I've seen posted, this is what I see as rebuild parts. What would be the most common ones to obtain for a generic rebuild? Presuming the crank package would have most of the gaskets?
Piston Package 2541330, one piston, one sump Gasket, one head Gasket and one valve plate gasket
Crankshaft Package 2815755, crankshaft, two head gaskets, two valve plate gaskets, sump gasket and front seal.
Front Bearing 2019681
Rear Bearing 1984152
Oil Pump Package 2021191
2275205 and 2252204 Reed Valve Plate
Also saw this on C bodies: sim to the one Classic Ind used to offer.
Anybody have a source for a full gasket set?
I have found that I enjoy an A/C system when it works really well. Unless you're doing the car to a 100 point concours condition, I would ditch the boat anchor and update to a Sanden compressor, modern parallel flow condenser, and modern barrier hoses along with a TXV that's calibrated for 134a. This will make the system perform great with 134 that's commonly available (for now). Not to mention the 20+ horsepower saving and probably 20+ lbs of weight savings off the nose. The car will be all around better for it. There's a recent thread on the A-body site about where to get the stuff...
