Nacho-RT74
and, as 72RR told, grounding sender wires and key in RUN, should speed out the gauges to max reading. then beging to track everything from there. at bulkhead for temp, kick panel for gas up reach plug at Cluster.
if not response yet, power to limiter ( which is the same than oil/brake idiot lights so if they turn on, that's not the problem ), limiter itself or damaged gauges
