Thanks Nacho! Yes Ammeter is working. So the instruments run on 5V?Well the good news is I think I found the problem.
The bad news is its a lot of missing connections. Over the years and a lot of Bubbtization lines were cut and spliced and not connected correctly or not connected at all or respliced with the wrong color wire. I found multiple wiring issues at both the dimmer switch and headlight switch. It totally explains the isses I have been seeing. These are the points of distribution from the schematic.
Now in order to fix it I can get a new harness or try and splice in the missing and chopped wires.
A new harness sounds nice but all that routing inside the dash which has piss poor access sounds like a lot of work. I know its the right thing to do but if the wires look ok I will work to splice in the right wires and try to use the right colors as to maintain the schematics accuracy.
Hopefully this solves most of the problems.
One question: where physically is the Voltage Limiter located? Is it on the PCB? Is it a metal can 3 prong device?
On the charging circuit wiring, yes, my preference is to rebuild the harnesses, replacing the 12-gauge charge wiring, with 8-gauge wire and by-passing the bulk head connectors completely for this circuit.
There was large C-body recall in the seventies that involved adding a parallel wire run from the alternator output stud to the “Batt” fuse box spade. How do I know? In my time working at dealers then, I probably installed hundreds of them, paid like .2 of an hour or something stupid, if you took the time to move the car into the shop, you were already upside down. Did most of them where ever I found them parked.
