IQ52
initially we went with a full turn on the valve adjustments and got lock up, then backed off to 1/4 turn and it seems fine, then one day while checking a compression tester we saw 45-50 lbs of comp?? way low should be up to 110+ right? Seems we thing the valves are still too tight. would backing off to 1/8 of a turn or less work to bring it back up? No other real problems other than crappy eddy 800 and little tweek on the timing.
Ouch, your valves have been hanging open. The XR274HR IS a hydraulic roller cam, they've had you trying to set preload on the 829-16 SOLID ROLLER lifters. You need the 8921-16 hydraulic roller lifters for that cam. .000-.004" preload, or NO MORE than 1/8 turn.
I bet your Edelbrock carburetor will even work better not having to deal with the combustion mixture now swirling around in the intake manifold from the open intake valves.
It's sorta funny......isn't it?
You could, if you wished, run those solid lifters for awhile. Just set the lash, real lash now, at .002-.004" cold gap between the rocker roller and the valve tip. It should open up to .007-.010" gap hot with the aluminum heads. I wouldn't run it for very long, but I'll bet that 493 really wakes up! You could set your timing, with that cam and 493ci, probably 16-18 degrees initial, 36 total, and do your carburetor tuning without hurting the cam. Of course, it's safest to WAIT FOR AND INSTALL the proper lifters.
