Here's the low profile Crossfire mechanism. $ 198.00 used.Glad to see back at it, creativity and all.
Nice artwork, idea sounds pretty slick too. I'm curious to see what you come up with if you decide to do it.
Looks like it's go time lol. Any chance you could get the formed pocket that it sits in or are you modifying the size?
It will go across the entire back end and up halfway on the slopes of the quarters. The tray it will sit in should end up about an inch deep or so. I really don't need the wing plate, just the mechanism. I'll investigate pushing those scissor mounts outboard another foot and a half as well. The way that thing moves is it lifts the wing up about an inch and a half then tilts the rear edge up from there. A sort of two stage movement. Which is what I would need too. That keeps the front edge of the spoiler from impacting the front lip of the tray. I'll cut out a template of the shape of the spoiler and get it sized and located where I want it and then trace a line onto the metal of the trunk lid and quarter tops. I should only need to cut the vertical walls of the tray from sheet metal as the cut out panel would serve as the bottom of the tray. Once the tray and spoiler are in and fitting like I want. I'll investigate the installation position of the mechanism and how the arms protrude through the tray, and where. This will ensure the least possible opening in the metal. Also it will be interesting to fix the contour of the spoiler to match the shape of the cross section of the deck lid and quarters. My idea is to use a length of bendable metal rod to get the matching contour shape 360* of the spoiler edges. Once that can be set inside the tray on spacers so that the top of the rod is flush all the way around when viewed from on edge across all of the surfaces , THAT will be the frame upon which I hang fiberglass. With a metal mesh to fill in the inner space between the rods. Should be stiff enough to hold up. This will allow me to get the contours right with out needing a shrinker/ stretcher which would be tedious in metal. Should work. lol.Looks like it's go time lol. Any chance you could get the formed pocket that it sits in or are you modifying the size?
They way I see it is that the trunk lid is curved down from the center to each side. The quarter tops curve down as well to the gutters except for the last couple of inches. There I would make the tray slope to the gutters on each side just a bit. The gutters are about 1 1/4" deep relative to the deck lid surface.Three piece tray, quarter trays with their own drains, dropped down the thickness of the spoiler and the spoiler running past the deck lid when it's open. The center drain hose in the deck lid could drain by the rear wheel wells, like the windshield washer hose on cars that have the squirters mounted on the hood. I don't know if I said that right.
You are totally nuts sir, and I love it!!!It will go across the entire back end and up halfway on the slopes of the quarters. The tray it will sit in should end up about an inch deep or so. I really don't need the wing plate, just the mechanism. I'll investigate pushing those scissor mounts outboard another foot and a half as well. The way that thing moves is it lifts the wing up about an inch and a half then tilts the rear edge up from there. A sort of two stage movement. Which is what I would need too. That keeps the front edge of the spoiler from impacting the front lip of the tray. I'll cut out a template of the shape of the spoiler and get it sized and located where I want it and then trace a line onto the metal of the trunk lid and quarter tops. I should only need to cut the vertical walls of the tray from sheet metal as the cut out panel would serve as the bottom of the tray. Once the tray and spoiler are in and fitting like I want. I'll investigate the installation position of the mechanism and how the arms protrude through the tray, and where. This will ensure the least possible opening in the metal. Also it will be interesting to fix the contour of the spoiler to match the shape of the cross section of the deck lid and quarters. My idea is to use a length of bendable metal rod to get the matching contour shape 360* of the spoiler edges. Once that can be set inside the tray on spacers so that the top of the rod is flush all the way around when viewed from on edge across all of the surfaces , THAT will be the frame upon which I hang fiberglass. With a metal mesh to fill in the inner space between the rods. Should be stiff enough to hold up. This will allow me to get the contours right with out needing a shrinker/ stretcher which would be tedious in metal. Should work. lol.
Absolutely nuts. Thank you for noticing!You are totally nuts sir, and I love it!!!![]()
I read that twice and still don't get it. Got a drawing? or type it slower? lol.Build the tray with the bottom in it, flip the deck lid, inside facing up. Jig the deck lid so it stay in its original position. Die grind a slit through the bracing and drop the tray in and weld in place. Run angle iron to the tray on both ends and in the center on the bracing. Angle across the tray and over the the angle on the bracing and weld. Flip over and cut deck opening. Make spoiler out of 1/8 inch flat stock and curve up the ends to match the quarters.
I love it.Absolutely nuts. Thank you for noticing!![]()
1/8 steel flat stock, weld. More rigid. Put the bends in the ends where it goes over the quarters. We're way past worrying about weight.Yeah, I too forgot how deep those ridges were..
How about fastening the lift arms to the underside of the al u mi ni um?
Hmm. Not sure the little motor will lift that much weight....That Crossfire wing is tiny.1/8 steel flat stock, weld. More rigid. Put the bends in the ends where it goes over the quarters. We're way past worrying about weight.
It might be geared more than you think, need to be checked out.Hmm. Not sure the little motor will lift that much weight....That Crossfire wing is tiny.
