Derwud
Um, NO!! You should have been advised and given options to correct.. $375 sounds like a restoration price, not a make it work price.
i ask you this Respectfully,would it take you or your shop 3 hours to " restore " that barrel ?$375 is only 4 hours + $75 in parts in my shop...
He's Canadian so who knows how long 3 hours is in "metric"?i ask you this Respectfully,would it take you or your shop 3 hours to " restore " that barrel ?
No mention if the unit actually worked before sending it out. If it did and all that happened was slapping on a coat of POR 15 then the cost is a disgrace. If it didn't work and has been taken apart and the internals repaired I can see spending way more than 4 hours on it. As for the outside expecting to come back smooth, that's coats and coats of primer, sanded back off until the pits are filled.... or bondo and the same work = hours. The rear axle in my Bee was 10 coats of epoxy primer on and sanded back off before it was shot with final colour.i ask you this Respectfully,would it take you or your shop 3 hours to " restore " that barrel ?
THAT barrel ... you couldn't do it in 3 hours. Personally I think its too far gone for a "resto". Filling something with bondo hardly qualifies as "restoration" !!i ask you this Respectfully,would it take you or your shop 3 hours to " restore " that barrel ?
I'd put a Hefty Bet on it NOT being Topher's, the Headlight Motor Man !!!Can you tell us who the rebuilder was or at the very least his location?
oh hell noI'd put a Hefty Bet on it NOT being Topher's, the Headlight Motor Man !!!
I wished he would of called me and told me. Live and learn to ask everything before I send out anything. It was rebuilt.Uhh, no.
Pits in the surface cannot be sanded out because they are areas where the metal rusted away. That wiper motor was heavily pitted before the rebuild. It would be unreasonable to expect the rebuilder to do what equates to "bodywork" to the housing unless it was agreed upon beforehand.
If it functions properly, maybe consider a wrinkle finish paint to disguise the rough finish. I'd be okay using it in one of my cars if it functioned right.
Yes it wasI would agree with the bet that this is NOT Topher's work.
He should of called me,I expected it to be restored.if I had sent if off to be repaired I'd be ok with that .But to pay for a "restored" piece ,oh that wouldn't be acceptable . if the person doing the work seen the surface after blasting he could have known it would not clean up and notified the client . if it was agreed upon by them both to go ahead and finish then that's a different story .
