18x9.in front
chubbz_34
5:37 AM
Newark
What do i need to do so i can put 18x9 wheel in the front On a 70 Plymouth satellite. Befor I get people getting on here and replying why I'm going that big, not to do it, it hard to do, stay with smaller wheels, and so on and so on. I jest what to know what I need to do and spend.
i got 18x8.5 in front on mine with 4.5 inch backspacing. hope this helps you out.
i got 18x8.5s on mine as well with 4.5 back space and they fit well no issues.
Well first thing i would do is to buy this tool...it helps you measure you tire and wheels combo !
18X9.5 with -12mm of offset or 4.75" of backspacing. With wilwood brakes it pushed the wheels out 1/4" each size. I wish I would have gotten -6mm offset for the front. With stock brakes or disks that do not push out your track with the -12MM on 9.5" wide rim will work great. I am running a 265/35/18 and could run an 285/35/18 if I had the extra 1/4" of backspacing.
Thanks guys. another thing what size wheels are you guya running
Sorry not wheels but tiers. Also are you guys running spacers because I only find Truck and custom wheels with 4.5 backspace.
Mine are 18x9 with 4 5/8" backspacing. I ordered the wheels and was able to have the backspace almost anywhere I wanted it. 275/40/18 up front.
18x10 out back with 4 5/8" Backspace on an axle 1 1/2" narrower than stock. 295/45/18 rear tires.
thats a sweet looking 70 kerndog.
which wheel width did you get and which BS?
