Mike Gaines
- 11:00 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
Just curious as to if you have tried a non liquid filled gauge ? I here the liquid filled gauges will bounce around some. So it makes me curious if a non liquid filled gauge will read the same ? Ron
Ron, I originally bought a NON liquid filled 2 5/6" gauge to mount on my cowl (from Summit).
I installed it and it bounced so bad I couln't even see the needle.
Summit Tech told me to go to a Liquid Filled Gauge to alleviate the bounce...which I did...it bounces much, much less than non liquid filled, but still bounces.
Maybe Im going to learn something here but having -6 feeding 2x -6 carb lines and a -6 return seems all wrong to me.
I run -10 feed -8 bypass and -6 lines to carb.
Again I might be going to learn more but I am shocked with the pump size as well. Magna fuel rate there 275 GPH pump for "up too" 750 hp . How can a 140 with -6 feed be right ? Ive been around the drags for a while (not as long as you Mike) and if I was doing the fuel system for your car Mike it would go roughly like this : -10 tank to pump, 200+ gph pump, -8 feed to hi flow reg, -8 return and -6 to carb.
Just my thoughts.
Ozy...your points are well taken, and thank you.
PS: When I was racing my 1963 Max Wedge Aluminum Nose car in 1963/1964/1965 we used 2 Stewart Warner Electric pumps mounted back by the gas tank and that was it....we knew nothing about fuel pressure and fuel pressure regulators.
In 1966 to 68 when when I was running my Funny Car I had Hilborn Fuel Injection and there was NO accomodation for fuel pressure readings. You just put the big jets in for 80% NitroMethane and then "tuned" it by the size of the bypass pill (inline jet) going back to the fuel tank.
for carb systems if you run a # 6 supply it need an # 8 for the return, that means all fittings,no adapters.
efi is different because it is high pressure.
also the liquid filled gauges , when they get hot do not read correct.you have to open the little rubber cap on the side of the gauge to equalize the pressure that has developed from the oil expanding.
CDR: Thanks for your input. Everything I read says to use a bigger bypass return line (like 8an) than the supply line (which is 6an)....but I called Mallory Tech and Summit Tech and they both said a 6an return line was OK....but...maybe in real life it isn't. Thanks for the input.
And yes, I know about the little "cap" that you lift to "vent" the liquid filled gauge to equalize the pressure and I have done that...and it does "reset" the pressure...but still bounces when motor running..
