- 9:10 AM
- Jan 1, 2013
- Mascoutah, Illinois
Excellent update, evaluations, and wrapup once again Hawk
Excellent wrap-up Hawk, great info. . I will be interested in your breather line re-rout as I have had similar issue.
Hope car arrives home soon so you can get some autumn drives in.
...I'm quite certain when it goes back in you'll leave nothing to chance.
You can bet on that!!!
At the moment, I have the original 4 speed back in the car, and will likely run that for a little bit when the snow and salt is gone. But the O/D will go back in so I can continue to use it for long trips in the summer.
For now, it just sits in the cold crypt of my garage... :icon_sad:
Hawk, I hope all is well. I thought you were in line for one of the new Passon 5 speeds. Any word on that or is my memory failing?
I'm looking forward to more Lime green Mopar ****![]()
Thanks for checking in Jimi!Hey Guy's, been a minute....just sayin hey, ill be @ Van Nuys SF this coming wknd......good luck w/ gears Hawk.
Spking of gears, the bug has a 67 911 S t-axle init....decided to look on ebay to see the general ask.....i definitely do NOT want to break it.....10-11K on avg.....good news is they are good for 350 lbs tq as long dont stand hard on in first, and of course no clutch abuse, speed shift..
Im super diffing it, beef ring & pinion & kicking the final drive to the moo maybe 2:10.....make the power nice & usable, long throttle travel, keep the nose down, with radi, oil tank and coolers,,little added dead ballast, i think ill get a 55r-45ft bias, no worse than 60-40.....im really going to try for Bonneville next year.....strictly fun, have always wanted to go, now i have fun car, what better way to exp it? A couple decent angles here
Adios Amigos.....jimi
Thanks Hawk, no plan, just desire..ill checkThanks for checking in Jimi!
Your bug is cool as hell with some really neat work on it; I'm enjoying your thread. BTW, I thought I heard that the salt flats were having some issues and conditions have not been good to drive on it for a couple of years. You might want to check before you go!!!
I had an 88 LX moostang, yeah in 5th (od), tach showed 1900 @ 80...had the car to 135 a couple times, worst brakes ever ..Just cut that tunnel up and put a T56 in it.............. 80mph hour @ 1,800 rpm ahhhhhhhh.
I really hope they get the supplier issues sorted out because there's a long waiting list.
I hear you. I am not thrilled about how long it has taken, and there is no real date yet when I could expect to get one. Having said that, I already paid for an overdrive to be built into a 833 4 speed. The gear spread sucks since there are only 4 total gears, but the OD part works great on the highway with a .62 OD. Not quite as impressive as yours, but I am not sure I can now justify another interim solution. I don't want to cut up my tunnel, and my only other real option is to get a Gear Vendors for my original 4 speed. But the OD on that is only .7 so I don't like that either.Just cut that tunnel up and put a T56 in it.............. 80mph hour @ 1,800 rpm ahhhhhhhh.
Around here, the ability to really get the car up above 80MPH aren't so good. Too much traffic, too many cops, roads are really not good for it, etc. But when you do, having brakes, suspension and steering set up right is a must!I had an 88 LX moostang, yeah in 5th (od), tach showed 1900 @ 80...had the car to 135 a couple times, worst brakes ever ..
Hawk I really want one too when they are available and being produced as I don't want to cut my floor either. What is entailed and what is the cost to be on the waiting list btw
I'd prefer your .62 over my .5 6th any day although 5th in mine is wonderful, .62 would be about perfect for 3:55's.I hear you. I am not thrilled about how long it has taken, and there is no real date yet when I could expect to get one. Having said that, I already paid for an overdrive to be built into a 833 4 speed. The gear spread sucks since there are only 4 total gears, but the OD part works great on the highway with a .62 OD. Not quite as impressive as yours, but I am not sure I can now justify another interim solution. I don't want to cut up my tunnel, and my only other real option is to get a Gear Vendors for my original 4 speed. But the OD on that is only .7 so I don't like that either.
So for now I make do with what I got. The car is not a speedster but more of a cruiser. Until the kids get out of college, I may have to live with that!
Hawk
