Triplegreen500
- 9:44 PM
- Dec 3, 2020
- western Maryland
My driveway is at 1601' elevation, and "town" is in the valley (200' or so), so I'm up and down hills a lot.
Not exactly the best terrain for economy.My driveway is at 1601' elevation, and "town" is in the valley (200' or so), so I'm up and down hills a lot.
See, there's your problem, too much uphill driving! You should always try to go downhill only!My driveway is at 1601' elevation, and "town" is in the valley (200' or so), so I'm up and down hills a lot.
Reminder......There were NO 2.73 ratio Mopar axles. The 8 1/4" had a 2.71 though. The 8 3/4" axle had a 2.76.@tripplegreen500
My 73 satellite 61,000 mile 318 with 2.73 8.25 gets real world average 14.5 MPG.
Almost bone stock 2 barrel with a partial open element air cleaner, timing at book spec 0 degrees, and dual 2" exhaust.
My car is a stripper so likely weighs less than yours (3700# without me, but with a spare, jack and speaker box in the trunk).
I say you are in the ballpark
I know it's not apples to apples, but I have a really nice '84 W150 w/ a 318, it had a 2 barrel and ran so nice and smooth you would of swore it had efi.
Anyway, I put eddy 4bbl intake and 600 Holley on it, just so it had "some more suds" and fuel mileage actually increased.
We have a 1986 360 camper van Dodge 350 series. Bought it in 2009, 59000 Kilometers. Had a Rochester quadra jet. Took it on a cruise to Texas and other points. It was a DOG no performance 8-9 miles per gallon Canadian. Had the carb rebuilt, still not good. Put a 4640 Carter on things improved. Then my friend did a little work on a Thremoquad I had. Now I have gotten as much as 17.5 mpg Canadian. Also don’t have to put it into 2nd going up a certain hill.When I swapped out the 318 2bbl in the van for a 360 with LD4B & Carter 650, Comp260HE & cheap headers, picked 3 MPG average & 5MPG towing the 5500# race car & trailer. And the 360 could go up hills with no trouble.
10° before is my baseline. You can advance it a degree or two at a time and test. Listen closely for detonation though. It might run better close to 15 but there are some factors to make it so.Well I was doing some other electrical stuff on the car yesterday (3.5h to get the horn sorted out and working), so I checked timing while it was still warm. Unhooked the vacuum advance and corked it, 10*BTDC at idle. The book says TDC +/-2, and it runs well, so I'm just going to leave it there. I certainly don't want to retard it, but I'm hesitant to advance it much further. Thoughts? Advance till it pings, then back it off? Or leave well enough alone?
Good to know, thanks. Looking at the book, I was already 10* advanced so I didn't want to push it. But I also figure now's as good a time as any to advance a little, with it being 95 degrees outside...if it's gonna ping, it'll be when it's hot!10° before is my baseline. You can advance it a degree or two at a time and test. Listen closely for detonation though. It might run better close to 15 but there are some factors to make it so.
Yes, that much had latched itself onto a brain cell I didn't drown back in the dayadvance until ping under load, then back off until no ping
Those had the A 999 transmissions. 2.75 first gear instead of the 2.45 that the older 904s had. 2.2 axle gears though!My 84 gran fury 318 la got 24 mpg when it had around 50k on it and that was driving around 70 mph. Just a lock up torque converter no overdrive.
In some cases, it can be hard to get a stock 318 to detonate. They claimed a 8.2 compression ratio but that is BS...advance until ping under load, then back off until no ping
