- 12:12 AM
- Jul 17, 2008
- South Jersey USA
must every thread devolve into slap stick comedy?
Hopefully.must every thread devolve into slap stick comedy?
YES!must every thread devolve into slap stick comedy?
On the advice of a friend of mine, who owned a body/paint shop, I rarely wash my old cars with a garden hose and water. He said that once an old car has been disassembled and reassembled during a restoration, it may no longer be sealed against water intrusion as well as the factory did it. Water may find its way into a car in a way that is not very obvious, and lay under trunk mat, carpet, etc. to eventually cause rust. His suggestion was to use something like a California Duster to remove light road dust, and then to follow up with a spray instant detailer. I have done this for years. Our old cars never get that dirty, anyways.
I do not know what else I could have done when putting the window gasket in. We put plenty of sealant in the lower corners and across the bottom. Especially in the corners and down the A pillars. Not able to find the old butyl calk used the urethane. I won't talk about the rear window. So far it is dry. Well thanks for all the ideas and will try all but burning down the car. LOL. Has anyone tired the black RVT to help seal the window. Just a thought.
Not surprised, did you do my test mentioned in post #14 ? That was the FIRST test we did and almost always revealed the pivot seals as the culprit.So, I got into the car and under the dash with a Led palm light and mechanic mirror. Have been noticing that my pivot seals under the wiper arm look like bacon. I mean fired. Yes, it shows water is coming in around them. I ordered the set from year one cowl gasket, grease fitting, and the pivot seals. Is there a better place to get the pivot seals or are we just stuck with this reproduction stuff. I mean these things just did not last long. Is there a way to keep them from detreating and last longer.
My current GTX got a new OEM floor pan and trunk pan while the selling dealer was still using it as a daily driver, thanks to leaks at both windshield and rear window. The fact that he was a dealer didn't seem to have any effect on the factory build quality when he ordered the car.Every Mopar from that era seems to leak from the windshield and backlight.
