- 10:47 PM
- Apr 13, 2012
- Granite Bay CA
I have noticed that my alternator often fails to keep up when I'm at idle with the headlights and A/C going.
The car.....
I have a rebuilt 63 or 65 Amp alternator, whatever the highest one was for these cars.
If I am idling with the headlights on and the basic stereo on, it isn't terrible. Maybe 11.5-12 volts? At 1800 and up, the rate jumps to the 13.0 and up range. Cruising at 70 mph and 2200 rpms, it is solidly in the 13.7-14.0 range whether I have headlights on or not. I do have relays for the headlights, bought from FBBO member CrackedBack.
There is something about the A/C though. That fan motor really sucks the juice. At stoplights at night, headlights on, A/C going and brake lights on I'm dropping below 10 volts. I have no electric fans or fuel pump drawing power so why is it dropping so much? Can a stock alternator be rebuilt to put out more power at idle?
Randy/ 1 Wild R/T suggested this:
These brackets allow the use of a Toyota based Denso 60 amp alternator. That is lower than stock but it probably puts out more power at idle. I'd need something with a 2 groove pulley since the A/C compressor needs 2 belts to avoid slippage.
I'm not looking to jump right into this, I'm just testing the waters,
If you have dealt with the low output at idle, what did you do?
The car.....
