- 12:54 AM
- Apr 13, 2012
- Granite Bay CA
My cars have equal numbers left and right. The roads here don’t have much crown and my cars dont pull to either side.
With enough caster road crown doesn't matter..My cars have equal numbers left and right. The roads here don’t have much crown and my cars dont pull to either side.
I haven't seen it mentioned whether the OP is using radial tires or not.the service manual does say a 1/4 degree of less positive camber on the pass side
no not physically but mentally yes lolI haven't seen it mentioned whether the OP is using radial tires or not.
You have to understand that the specs for these cars were a product of their time and that things do change.
You don't have a completely stock engine anymore do you? Many people change the compression ratio, the camshaft specs, the piston ring gaps, adding electronic ignition, etc.
Do you run 110 octane fuel like what was available in 1970? I doubt it.
Alignment settings as specified were written for the masses. They had to account for the possibility of a skinny framed old lady or a burly Longshoreman. Bias ply tires didn't roll or steer as easy as radial tires do so the alignment settings had to aim for easier steering. Positive caster increases steering effort but greatly aids stability. The more caster you have, the more the car wants to maintain a straight line. Overcoming that takes increased effort. It is because of that that the FSM often called for greater caster numbers with cars equipped with power steering.
Still, even with manual steering with radial tires, you should be just fine with 2 degrees of caster unless you are physically compromised.
Maybe I read this wrong but....gtxrt, IF you move the cam adjusters the SAME amount equal but opposite directions will affect camber without changing caster.
I lowered my 66 and imo, it felt lots better. Didn't go nuts with it but it was down in the front by at least 1 1/2". The back lowered itself when the leaf springs went flat lol.I prefer stock ride height when possible. I think it's easier on parts and your butt.
When I started getting interested in handling I noticed that the late 70's cop cars had noticeable camber. You could actually see the camber! The first time to see it made me think the front end was worn but the cars were new and saw many more like that. In the late 80's early 90's my 66 exhibited the same thing and it handled great. Of course more caster was added which also help freeway speeds (and faster) tracking. Also, the more camber needed a tad more toe in....and tire wear was great. Don't have any specs since all of my alignments were done with levels, string and tape measures and some trial and error adjustments. Where's j-c-c lol.Some people just accept that these cars are old and that they are incapable of handling as well as new cars. That isn't accurate. These cars can handle quite well when the proper parts are used and the alignment settings deviate from what the service manuals called for.
Oh yeah, years ago a shop did an alignment on my vehicle.....and they went full circle with the adjuster cams. I guess you know what that did. Oh was I pissed!!! After that is when I took a real keen interest in doing my own.....there was one other that made me do it too but his mess up was minor.Maybe I read this wrong but....
If you adjust the front cam IN and the rear cam OUT, you reduce caster. If you adjust the front cam OUT and the rear cam IN, you increase caster.
When you adjust both IN, you add negative camber. With both cams going OUT you add positive camber. Adjusting them in opposite directions does affect caster.
Probably wouldn't hurt but on the other hand, probably wouldn't bother anything if you didn't. It just depends on how much you plan on moving the front one.one last question if I just want to adjust the front pass side adjuster do I need to loosen the back adjuster.
I like to loosen the other if the adjustment on the other one is going to be big.....No. You can adjust one at a time.
just going to move less then 1*I like to loosen the other if the adjustment on the other one is going to be big.....
