Edelbrock AVS2 Vacuum Ports and Adjustments
boboh1
1:09 AM
Claremont,CA
Adding the AVS2 to my stock 383. The manual states to check the old carburetor vacuum port to see if there is full vacuum at idle or not. My old Carter did have a vacuum so I should then hook up the vacuum line to the drivers side port on the AVS since the passenger side is for port timed. So how do I adjust the idle adjustment screws with my vacuum gauge if the open connector does not have a vacuum at idle? Maybe temporarily disconnect the distributor vacuum line and hook up the gauge to that for the adjustment?
You could do that, or use a t, or just do it by ear.
The ported fitting shouldn't be giving a vacuum signal at idle. The driver's side fitting is manifold vacuum, usually intended for cars with transmission vacuum modulators (also refer to the Edelbrock online setup/troubleshooting videos). Does the rpm change while adjusting the screws at idle? Try adjusting the mixture screws to obtain the highest rpm and readjust the curb idle speed afterwards.
Thanks for the responses. It is one of those why didn’t I think of that answers. Will use a T connector and check it that way.
The man vac port on the driver's side is NOT there for the express purpose of a vac source for auto trans that use a vac modulator, although it can be used for the vac mod. Original vac mod cars used a 1/4" fitting; the vac fitting on the carb is 3/16". GM cars used manifold vac adv until 1968 & THAT is what that fitting is for. It can be used as a vac source & T'eed off if needed as long as the correct size fitting & hose is used.
