khryslerkid
- 2:54 AM
- Mar 10, 2010
- Hanover, Pennslyvania
I've always thought that adding a zddp additive to oil was overkill and maybe even harmful to oil that was already formulated for a reason. This article/thread proves that adding zddp to any oil can deplete the amount of pressure that the oil already had in the original formula. (I copied just a few highlights.)
Zink Myth and Test Data (Website Speed Talk from 2013)
You DO NOT need a high level of zinc in your motor oil for adequate wear protection in high performance engines, not even for flat tappet engines. Contrary to popular belief, the zinc level alone is NOT what determines an oil’s wear protection capability. Zinc does NOT build up a coating on parts like some sort of plating process. Zinc is consumed/sacrificed A LITTLE AT A TIME as needed by the heat and load on mating parts, to help prevent wear as the engine is operated. And it is physically IMPOSSIBLE for more zinc to provide more wear protection, because zinc simply does NOT work that way. More zinc simply lasts longer because it takes longer for a larger quantity of it to be depleted. It’s much like the way more gas in your tank takes longer to run out, but more gas in your tank does NOT give you more HP.
The thinking that more zinc provides more wear protection is only FOLKLORE that has been repeated so many times that most people just ASSUME it’s true without any proof. And repeating wrong information a million times will NOT magically make it become true. Among those who just assume it is true, includes people at Cam Companies, and even people at some of the smaller Oil Companies who apparently don’t bother to perform any wear protection testing, since their oils often fall WAY SHORT of their own outlandish hype. The fact is, there is absolutely NO real world test data proof to back up the incorrect urban legend that more zinc is needed for more protection. That is merely a MYTH that has been BUSTED by actual real world dynamic motor oil wear testing under load. An oil’s wear protection capability is determined by its base oil and additive package “as a whole”, NOT just by how much zinc is present. And newer motor oil anti-wear additive components that have replaced a good percentage of the zinc that used to be used, are equal to or better than zinc. There is absolutely NOTHING magical about zinc that makes it the only component worthy of being used.
88. “ZDDPlus” added to O’Reilly (house brand) 5W30, API SN, conventional = 56,728 psi
zinc = 2711 ppm (up 1848 ppm)
phos = 2172 ppm (up 1356 ppm)
moly = 2 ppm (up 2 ppm)
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 38% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
89. “ZDDPlus” added to Motorcraft 5W30, API SN, synthetic = 56,243 psi
zinc = 2955 ppm (up 1848 ppm)
phos = 2114 ppm (up 1356 ppm)
moly = 76 ppm (up 2 ppm)
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 12% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
90. “Edelbrock Zinc Additive” added to Royal Purple 5W30, API SN, synthetic = 54,044 psi
zinc = 1515 ppm (up 573 ppm)
phos = 1334 ppm (up 517 ppm)
moly = 15 ppm (up 15 ppm)
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a whopping 36% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
Zinc Myth and Test Data on a Dozen more Oils - Don Terrill’s Speed-Talk
