kb67mopar
Alright time for a bit of venting.
So about 2 months ago I stop at the gas station to fill up knowing I need about 20 gallons. Start filling and the pump kicks off after 2 sec. repeat about 4 times...hmm must be the pump. Go to another pump...same crap. pull the nozzle out and try with an air gap and the fuel bubbles up in the filler. (obviously air is not venting properly from the tank). So after some fiddling with it and a few more tries no luck so I take it home and pull off the vent tube at the canister, suck some nasty fumes thru and free up the check valve...take it to the station and vioila...fills like new.
Fast forward 2 months
long story short its happening again. Do some internet searching and find a TSB on the problem...lone behold its common on just about every Chrysler vehicle from 03-08. Some vehicles were lucky enough to have the tank warranted for life because of it (durangos, jeeps, and some Rams)
Me I am SOL. Chrysler in their infinite wisdom molded the check valve into the tank so its not serviceable. So after some talking to the dealer and finding how screwed I am, I find that the tank alone is $507 of which they will help with NONE.
I have since freed the valve in the same manner as last time hoping it will last til warmer weather so i can drill a hole in my tank and put in my own check valve ....Thanks Chrysler!
