The Carter tuning manual I have suggests turning the mixture screw in 1/8" turn after reaching maximum RPM.
It says it helps keep the plugs from getting fouled. I've done it this way and it works well.
Idle speed is really a trial and error thing. If you have a tight converter raising it too high is a bad idea, then the car wants to pull at a stop and it just heats up the trans fluid. Just high enough so it doesn't shake is how I do it.
Is your vacuum advance working? Did you have it capped when you set the timing?
