Malex, thank you the support.
I am not an engine builder by any means, so some of this may be wishful thinking...lol. My current plan:
Build a street friendly engine that produces a lot of reliable torque and HP. That can run on pump gas. Sit and idle at multiple red lights without over heating...but when the gas pedal is pushed, it takes off like a bat out of hell. When you hop in it, it starts every time. The current plan is run a 4 speed transmission. For me a manual shifted car makes street driving much more fun. It will make an occasional pass down the 1/4 mile.
So,
1) See if the block is worth using.
2) A slight ridge can be felt at the top of the cylinders, I would assume that ridge is where the top of the piston stops before heading back down the cylinder? There is some pitting in some of the cylinders which will probably require boring?
3) It has a cast crank shaft, I am not a big fan of cast cranks...would like a forged crank. Is the forged crank worth the cost? Being that the primary use will be street driving.
4) If I end up buying a forged crank, I might as well get one that is stroked? Or should I find a forged steel stock 440 crank?
5) Would like some good breathing heads...is it worth the money to buy modern aluminum ones? Or have stock ones worked over by a machine shop?
6) A cam that has a good lope at idle but doesn't idle so rough that it has bad red light manners.
I am sure I am missing something but, all of this will need to happen on a poor pipefitters budget...
